This is bullshit! What do you mean the "ends are larger diameter" ? How do you suppose they got the rockers on ?!?!?
What I "think" you have are pieces of **** stock rockers that have been overtightened to the point they are now oval. Cut the shafts in half, remove the rockers and get a new, decent set of shafts !!
As for adjustment, you can use the attached chart to adjust them. "Zero" lash is determined by spinning the pushrod with your thumb and forefinger as you tighten the adjuster. When it won't spin its at "zero", now tighten 1/4 turn more and tighten the locknut.
Okay, okay. I didn't mean to get you so fired up, just reporting on what I found. That’s *kinda* what I thought was going on, but I didn’t see that happening at 25ftlbs or whatever the torque specs is. They aren’t exactly thin. Assuming that’s what wrong with them, then holy crap someone must have went at them with an impact gun or something LOL. I’ll double check them tomorrow night.
At this point I’m thinking to just swap everything out anyway. At the very least, I’ll know what’s in the car and the status/history of the parts.
Caution here - todays lifter you may not feel any resistance to spinning the pushrod. I prefer to both watch the lifter plunger (factory head) and lightly pull up and down on either the pushrod or rocker while turning the adjuster between your fingers.
The instructions for the lifters call to tighten until there is no more up/down movement. They seem to spin relatively free, so not sure I’d know exactly when it’s at zero by turning them. I tried both methods and I felt the up/down method was a bit more definitive. I otherwise have no preference.
The Cranes had wear issues back in the mid-seventies. That was the first bad set I'd seen on a buddy's '70 440 RR. It has nothing to do with age, you get a good set or you don't - simple as that! The few the OP has look just fine. Knock of the scare tactics and conspiracy theories !!
These are perfect, so far. I have no idea how many miles are on the build. It may have as few as 2000 miles on it.
So... then. If I want to swap out my rocker assembly, then I need to figure out the ratio of what's on the car, so I can get a set that matches. Bullocks. Looks like pretty much all rockers are roller so I guess that's an upgrade.
