Roman1970RR
Good day all,
Hey everyone,
I’m looking for some help diagnosing heating issues with my 1970 Plymouth Roadrunner (512 stroker, 400 block). Interested to hear from others running a similar setup to see if I’m missing something. I am seeing steady temp increase and have to pull over as CTS heads towards 220F mark.
Hey everyone,
Car & Engine Build Details
- 512 stroker (400 B block).
- 1080 CFM throttle body with Holley Terminator X EFI.
- Indy single-plane intake, Trick Flow 270 heads, 242/248 cam.
- Mechanical water pump from the 440
- TTI headers ceramic coated 1-7/8" to 3" collector and 2.5" exhaust.
- Cooling system: aluminium 2 core (Large Core) radiator and 2 x electric fans (No shroud and air in isn't sealed to stop hot engine bay air being recirculated.
- Peak power: 682 HP @ 5500 RPM, Peak torque: 702 lb-ft @ 4800 RPM (Allegedly).
- 355 diff ratio (3000 RPM at 100kph or 60MPH)
- 727 torqueflight rebuilt with manual valve body and aluminium drum.
Main Suspicions
- Incorrect tune (timing or running lean)—I improved things by increasing timing at cruise, but I don’t want to advance it further because I’m already at 38° and don’t have a knock sensor.
- Cooling airflow issues—No cowling on the backside of the radiator, and the front airflow seal might not be working properly.
- Thermostat issues—Possible incorrect thermostat restricting proper cooling.
- New engine breaking in hot—Could this be a factor?
