Roman1970RR
My latest timing map is in my pictures on original post I was running a smoother one at 36 deg cruise then went to 37 deg cruise which I noticed the most improved.Sounds like you found a solution. Let's see timing? I happened to mention that above.
Bottom hose has the spring. Bottom hose has the spring. Bottom hose has the spring.
I am getting a hose with spring this morning, I am getting a hose with spring this morning, I am getting a hose with spring this morning
This must be what Bart Simpson feels like
