- 11:04 AM
- Jul 17, 2008
- South Jersey USA
I always attribute a minor spark when connecting a battery, to radio memory or clock
Big shout out to 1 Wild R/T and the others helping Kern. When this is figured out o think a “sticky” is in order to help debug electrical issues but that’s meI think that I found it. The stereo constant power wire is on the unfused side of the fuse panel. This is why pulling the fuses didn’t help and the issue was narrowed down to the one unfused wire on the relay. Now I need to reroute a couple of terminals since in error, I have a few things attached to the wrong side of the fuses.
Heck yeah!
The battery itself already loses charge but the draw of constant power only sped it up.
I would not have looked this deep if not for Randy, 1 Wild R/T.
Thanks!
And before the Lithium battery protests start
- just to point out what KD has learned - these are the safe Lithium Titanate type, not prone to fire and issues like the Lithium Ion type.
I was originally turned onto this exact battery by Mopar Action's Rick E and bought one after also watching a fire safety comparison video on 3 different Lithium battery types. This battery is legit and works great.
Do they sell a group 27 equivalent?All of the trunk mounted battery stuff is out and the return to an engine bay battery location is almost complete.
The battery box, solenoid, 1/0 positive cable, 4 ga full length ground cable, trigger wire and power wire are out. When added together, the whole trunk mounted battery setup weighs 18 1/2 lbs.
The traditional engine bay setup uses a thin gauge battery tray and support bracket. This was sandblasted, primed and painted....
I cut down a flor mat to use as a pad.
I'm going to reuse the trunk mounted battery cables but shorten them. It looks like the parts used to mount the battery in the stock location weigh about 4 1/2 lbs total. This means that when you look at the 18 1/2 lbs that the trunk mount stuff is put against the 4 1/2 lbs for the stock location, moving the battery to the trunk adds about 14 lbs.
When I replace the battery, I'm strongly considering this Lithium battery:
FBBO member 68SportSatellite has one in his Plymouth...
It weighs 7 lbs. My battery weighs 40 1/2. There is 33 1/2 lbs of weight to lose right there while getting much faster cranking speed when starting. 33 1/2 plus 14 means 47 lbs off the car by switching to a lightweight battery moved back to the stock location.
But doesn’t the weight of the battery over the axle help traction?
Of course, silly me, who doesn’t like a peel out !There are several variations of size and capacity.
I actually like peeling out!
Yeah, you are right though. There is some truth to the more traction theory.
I was in the same boat. Had a tender for the rider mower so in the winter I used it for the cars and no go. Called them and said to small and recommended 4 amp and did and issues goneI had a battery tender on the wife's Lincoln and it started showing a yellow light all the time meaning it was charging constantly. Never turned green and voltage would only get to 12.4. I sent email to battery tender company asking what voltage it should go to, to turn the light green. He said at least 12.6. He asked what size Tender I was using. I had 1.5 Amp on it. He said I needed at least 4 Amp for a car battery. I put 4 Amp on and it charged it up in just a few hours and now turns green and voltage is at least 12.6 all the time. I thought battery was dieing when it was actually the battery Tender. I had been using it for probably 3 years
It was either close the thread or ban most of the posters. (which I should have done) The trouble started halfway through the first page and then the testosterone took over. I don't think the op's simple question even got answered.Anyone hang out on the A Body Forum in the Ignition System
Good info , however
There was a simple ignition coil question on heat that turned into WWIII
Tried answering some of the O.P. s questions however
Anyways the thread got locked , still shaking my head
Carry on
“A” bodyitis lolAnyone hang out on the A Body Forum in the Ignition System
Good info , however
Carry on
I kind of tried answering - No one even noticed between all the testosterone LOLIt was either close the thread or ban most of the posters. (which I should have done) The trouble started halfway through the first page and then the testosterone took over. I don't think the op's simple question even got answered.![]()
I see Halifaxhops posted only once. Better to not get in the middle of it.I kind of tried answering - No one even noticed between all the testosterone LOL
Both are new.
I got the Tuff Stuff alternator from a fellow FBBO member and I bought the adjustable VR to limit charge voltage to 13.8.
The battery isn’t dropping voltage fast enough to piss me off but now that I see that it drops after just a few days, it made me wonder if it is related to previous troubles. I’m now thinking that it has probably been doing this for awhile. Who checks battery voltage each time they start their car? If it cranks and starts, you just assume that all is well.
A friend has his 68 Dart here, it has sat with the engine out for almost a month. The battery in it still reads 12.66.
