- 5:21 AM
- Feb 22, 2013
- The Red Anvil Dog House
I would go with a frame jig. As rotted out as that floor is I think a rotisserie would make it flex in the middle.
Excellent Point.I would go with a frame jig. As rotted out as that floor is I think a rotisserie would make it flex in the middle.
Ya...it's trashed!OMG. Jesus Chrysler. All the best. No one here has ventured a guesstimate.
Dash $10k?
Poke around on here. While I have no experience in building a custom frame jig, I'm sure that there are at least 3 members that have.Excellent Point.
Thank you! That's the direction I was leaning too.
Now comes the fun part: the design. Gonna watch a ton of YouTube videos.
I wonder if I can make a "universal" frame Jig. That's could be designed to adapt to other B-body cars? Nonetheless, the bird-in-hand is the 69 Roadrunner. That's our focus!
Thank you again for the guidance!
Semper Fi
Sabre_3
Well...ok....Ya...it's trashed!
I'll send some pictures ASAP!
Many thanks!Poke around on here. While I have no experience in building a custom frame jig, I'm sure that there are at least 3 members that have.
That's what this place is for.![]()
Absolutely amazing sir!Buying new or rebuilding is the biggest worry on any resto?
An R/T car has special parts that need careful resto.
A resto-rod can have R/T spec parts fitted and saves many hours of work.
Rebuilding the R/T springs was a nightmare and a weeks work.
Fitting new aftermarket springs is an hours work...
Here’s the frame jig I made. There’s a diagram on the web I built it off of. I built it a bit high so I could get underneath the body for floor panel figment and such. I would recommend you put it on rollers. After the one piece floor and one piece trunk floor and other repairs were accomplished I put it on the rotisserie. I can’t imagine have it on the rotisserie and doing that sort of work. Especially the rear cross member install.
With a tach no less. Nice!!!Well...ok....
We have a donor dash from a Satellite!
Good stuff!
Need some advice....
I have a lot of organizing, tagging, bagging and meticiculous inventoring parts. During this period of time, I'll be saving and building my financial resources to invest and commit to the restoration. So, which direction makes sense?
My Goal is a complete ground up restoration/resto-mod. Should I fabricate a Frame Jig or Purchase a Rotisserie?
Frame Jig Option: If fabricated properly, I could "lock in" the uni-body factory dimensions for precise reconstruction. Ideal for Frame Rail, Cross member and rocker panel replacement (if required). My concern is the Frame Jig may or may not be useful for other/future B-body Projects without modifications.
Rotisserie: facilitate ease of access to most/all areas of the car. Can use Rotisserie on other projects after the roadrunner. Might not be able to maintain factory dimensions if structural support needs replaced.
What would you all recommend?
Please advise.
Semper Fi
Sabre_3
Will do sir!Be careful pulling the rear glass. Harder to find replacement for that I’ve heard
