Sorry this is so long. Don’t try to watch the whole thing.
Try-outs for the Bullitt remake. Awesome burnouts Dennis.
How is your timing set and what spark plug are you running? It may need more advance if its laboring to idle once you let up. If possible get on the brakes and bring the rpms down slower rather then taking your foot off the gas quick. I doubt dying has anything to do with the transmission. You could speed your idle up a bit and see if it helps.
If your just running a radial street tire it is going to be a challenge to break anything in your driveline. I have no idea how your engine was built. If it was built w tight clearance give it a chance to cool between beatings.
You forgot to mention about the correct TORQUE setting of the RR tire valve stem and whether the valve stem cap is set correctly....VERY IMPORTANT CONSIDERATION or unequal traction may result.....in addition to the normal thingsThis.
And, try this as a quick fix as well:
1) increase your idle speed a few hundred rpm,
2) open your idle mixture screws a half turn.
Not saying this is the long term solution, but might get you through this in the short term.
Getting pretty good at trolling lol.You forgot to mention about the correct TORQUE setting of the RR tire valve stem and whether the valve stem cap is set correctly....VERY IMPORTANT CONSIDERATION or unequal traction may result.....in addition to the normal things
To be considered...radio station volume and type of wax used......just a thought.....
BOB RENTON
Poor old lonely guy has nothing of use to add in the conversation. Pretty sure he has no idea what BSB67 was getting at to help HAHNAGON out.Getting pretty good at trolling lol.
He is correct on the Radio Station and type of Wax though.Poor old lonely guy has nothing of use to add in the conversation. Pretty sure he has no idea what BSB67 was getting at to help HAHNAGON out.
Radio station should ideally be set to a mid-range FM for best reception....but as for the lubricant......To be considered...radio station volume and type of wax used......just a thought.....
I think in this instance the valve stem cap would be removed entirely to reduce un-sprung weight and inertia.You forgot to mention about the correct TORQUE setting of the RR tire valve stem and whether the valve stem cap is set correctly....VERY IMPORTANT CONSIDERATION or unequal traction may result.....in addition to the normal things
BOB RENTON
What if the tire was balanced with the cap on?I think in this instance the valve stem cap would be removed entirely to reduce un-sprung weight and inertia.
Nobody said that you can't remove the tire and check for balance after relieving it of the cap.What if the tire was balanced with the cap on?
TRUE......but removing the valve stem cap reduces the UNSPRUNG WEIGHT.......and inertia, (depending on RPMs and weight) is also an important consideration....but the real savings is air @ 48 F (508 A) a cubic foot of normal pressure sea level air weighs almost exactly 1 1/4 ounces and at a higher pressure, the heavier the air becomes......but at zero psi, there is no influence.....I think in this instance the valve stem cap would be removed entirely to reduce un-sprung weight and inertia.
What about if the tires were filled with Nitrogen instead of dirty air from a compressor that has one bad cylinder? Would that create less rolling resistance and a smaller magnetic field? Asking for a friend who doesn't own an oscilloscope.I think in this instance the valve stem cap would be removed entirely to reduce un-sprung weight and inertia.
