Has anyone used this seat foam?  https://www.classicindustries.com/product/all-years/dodge/all-models/parts/*md2007.html
My drivers seat is pretty lumpy.
Ya I know. I could go to my buddy's custom upholstery shop. He could hand sculpt foam (possibly made overseas) and rebuild my seats (not re-upholster). He charges at least $100/hr. It would probably cost upwards of $1000 I bet. I don't mind setting on imported seat foam. It's better than lumps. I'll look for that thread. Thanks for the tip.I vaguely remember a thread involving seat foam somewhere. Basically don't buy the chinese crap. lol
hell.. i find 299 too muchI see Legendary has what looks like the same foams. Only, $40 more.![]()
I agree there. I have some lower back issues and I need a comfortable seat. I may install one of those pump up lumbar support bags as well.hell.. i find 299 too muchbut good seats are worth the money..
It's funny but i don't care that much bout the outside of a car.. but the interior has to be niceI agree there. I have some lower back issues and I need a comfortable seat. I may install one of those pump up lumbar support bags as well.
My 66 is like that. Nice inside except for the headliner. The outside (paint is nasty) The wheels give it attitude though. LOLIt's funny but i don't care that much bout the outside of a car.. but the interior has to be nice![]()
I used it , the foam itself is fine but the problems is that you can't really use Legendary covers over it. If using Legendary covers use their foam, it is different.Has anyone used this seat foam? https://www.classicindustries.com/product/all-years/dodge/all-models/parts/*md2007.html
My drivers seat is pretty lumpy. View attachment 1829531
Man i love those opera lights.. i miss my 66 new yorkerI got my order in from Detroit Muscle so I was messing with my 64 this afternoon. I got a few things done. Just small parts and projects. One piece at a time making it better.
1) Quarter glass vertical weather-strip. It will be nice to not get the inside wet when it rains or with the garden hose. The old ones were originals and not much left. I also adjusted the drivers door a little tighter. It might need some other adjustments but it's much better now.
2) Front turn signal lenses. They were originals, all cloudy and one was scratched. The housings were crusty inside and the original gaskets were shot. I was thinking about LED's but they aren't really needed with new lenses and some cleaning.
3) I did get my mirror installed. I didn't plug the extra hole. I'll see how that goes later.
4) A small thing but license plate nuts and screws. I couldn't get them in the slots in the rear. The clips were too stiff or the slots are smaller than the standard squares punched like in the front bumper.
5) I drilled out the holes for the ignition ECU and installed 1/4" Nutserts. Boy that is much nicer! The sheet metal screws wouldn't tighten down and the ECU needs a good ground. I also rerouted the wiring to the distributor so it looks better.
6) I cut the strap off the battery and discovered there is no hold down. No biggie. It's on the list. I did order a sticker and cap kit from Wescar on E bay. That should spruce things up under the hood.
7) I crawled under and looked at the shocks. It bounces wonky over bumps so it must be the alignment. I'll have the wheels balanced and the front aligned. It looks like all new steering linkage. I hope the PO did all the bushings as well. The shocks look like new, front and rear. I bounced all 4 corners and no bouncing. The rear springs look new as well. Score!
Sorry to rattle on so long. I like to post photos to save on my computer and a timeline of what I do. I can also copy and paste this to my thread on B bodies. Got to make it easy!
My electrical and choke repairs worked well. I pumped it a couple times and it spun about a half turn and lit right up. I love that.
I see that. I will order from them sometime I bet.Van's Auto has a decent amount of early B bodies parts also, might be good to add to your list.
Those old lenses weren't in good shape. If the one wasn't cracked I could have cleaned them and polished the outside surface. It's cool to have the CDPD emblem on them. Those new lenses are so clear and bright though. These turned out so nice I might look for some for the rear.Man i love those opera lights.. i miss my 66 new yorkerThe turn signals look awesome.. thanks for not going LED
I would like some new lenses for my 62 but mine work for now. Nice to have door seals.. Mine are complete trash i just plan to never let it get wet
I see Van's has the headlight trim I need.Van's Auto has a decent amount of early B bodies parts also, might be good to add to your list.
Good to know on the foam. I made a Gif of a blinking turn signal but it didn't work. The file must have been too big.Makes for a cool avatar too!
Legendary is the best foam. Used it myself and several upholstery people I've talked to say the same. You get what you pay for!
Nicely done on the avatar photo! Welcome to b bodies have you signed in at the welcome wagonFinding a nice used pair is probably not going to happen. I might as well pull the trigger on the repops. Stimulate the economy, what the heck.
