Virg464
Looking for possible idea to track down for an issue (maybe it's normal).  66 Coronet, not really a street car, rough idle, built/building the entire wiring harness for the car.  Starts and runs fine, running lights, hi-low beam, gauges, elec cooling fans, elec fuel pump.  Everything works, but when it's running and I let it idle (approx 950-1000 rpm), the lights surge (intensity), the fuel pump rpm surges (pressure stays constant 7 psi).  Running a 60 amp OEM alt, using an OE style electronic voltage regulator, MSD 6AL ignition.  Off idle that all goes away.
I know this is a very general/non specific question, so any thoughts are appreciated.
