Which clips for interior panels ?
The install part is important, but for a vinyl door card , the flat one is better. The destructions show with the tool how to split the card board and get the clip on so it doesn't look like *** underneath the vinyl.
Again all shown in a restoration thread, but I digress.. ;o)
I used the ones in the second picture in our Charger.
Our (66 67) Chargers have the expensive extravagant full 1 piece vacuum formed carpeted door panels.. way more forgiving. Could use either clip
The FSM and parts manuals are pretty neat too.
I’ve found both in the 3 Mopars I’ve owned too. I prefer the stamped steel one but I usually tweak both styles when installing so that they pop loose a little easier for later removal. I think the stamped one don’t show through on the vinyl surface as much as the wire ones.
Closer to 7/8, definitely not 1 1/8.
The specs are in Class.Ind description.
Yes used them on both interior door panels just last week.
Gotta go with 7/8” also. I had a few missing & went to local upholstery shop & he gave me a couple for VW’s. Looked & worked identical.
