19 69 GTX
- 9:55 PM
- Apr 30, 2016
Ok I'm sure I'll get **** for it but the headlight switch on my 64 belvedere won't pull out only turns and it's gritty when it does turn. I assume the switch is bad as I'm getting no power to headlights because switch won't pull out at all. I've pulled pig tail and supplied 12v and got power for headlights at the bulkhead. Also I'm getting no power to fuse box only for the headlights all the rest of the fuses have power. I did bypass the the amp meter on back of dash so that's not the issue. Also can a bad headlight switch cause brake lights to not get power. I have power at pedal on both sides no switch is good
