Background:
1973 Plymouth Satellite, originally a 318/904 car, big block swapped last year with an RV 440/727 Auto. Intended for street driving, will never see the track.
Been chasing improvements over the last 12 months, so far:
Plugs show some oil consumption, presumably valve seals, some of the valve stems looked wet in the exhaust ports when putting the headers on. I don’t see any smoke on startup or under acceleration.
These plugs have less than 200 miles on them. Fuel injection keeps the A/F rates pretty lean so I believe all the darkness is oil.
What to do?
I have a second RV 440 (RV had 20k miles) that I planned to use initially. Unfortunately, the low miles meant short runs and the top end was rusted up from sitting.
Low mile engine rust. The non-rusty parts look extremely clean. It was a shame that it had so much moisture in it.
To remedy this, I planned to have someone disassemble and inspect the bottom end, hone, new rings and bearings and run with some new top end parts:
I have:
I considered doing the short block work at home, but its not something I have ever done before.
Given the compression test, I’m starting to think that I should just use the short block in the car, and drop by new heads and cam into that engine. I’m much more comfortable with that work than I am with the short block honing work.
If Im not seeing smoke at idle or under acceleration, is it reasonable to think the rings are ok? The quick dark staining of the plugs is giving me pause, Im thinking that old dried up valve seals are a reasonable think to suspect for the plug condition and the compression variance may be the valves left open for long periods between runs.
Im thinking the fresh stealth heads and low compression specific cam may be all I need at this point.
Thoughts here?
- 78 RV Motor, RV had 80k miles. Appears to have at least one rebuild, not sure when. Rod ends have hand scribed numbers on them. It has excellent oil pressure and is quiet. Other than having the pan off to change for a compatible unit, I have not had the engine apart.
- New Under Dash and Engine wiring harnesses
- Upgraded charging system per (72RoadrunnerGTX) Videos
- HEI Conversion
- Fitech Dual Quad Fuel Injection
- Factory Distributor from 78 RV Engine (I have two others, a rebuilt/recurved unit from HALIFAXHOPS and an ebay Rick Ehrenberg unit, switched back to factory to troubleshoot)
- Rebuilt 8 3/4 with torsen type posi, 2.73 highway gears.
- 155
- 150
- 150
- 145
- 148
- 156
- 150
- 162
What to do?
I have:
- 440 Source Stealth Heads
- 440 Source Adjustable Iron Rockers
- Hughes Whiplash Cam kit with lifters and timing chain
Thoughts here?
