DynamicXX
- 11:49 PM
- Dec 23, 2023
- Corbyville, Ontario, CA
So, I did do an extensive search on this topic, with mixed answer's, hoping this will pull some info for my application: 1969 Coronet, 383, 4 speed, Hooker Long Tube Header's. Power steering. I purchased a new mid 90's Dakota mini-Starter, after reading reviews for this upgrade. (Original starter was showing its age, and figured as I had the engine/trans out might as well do the swap). Starter is not fitting as it's hitting the header. Some post's mention the Power Master 9523,other's saying to go back to factory/or original starter with heat wrap, etc. Any advice for "my" set-up? I had the Header's Ceramic Coated, so not too keen on taking a mallet to it...
