- 3:57 PM
- Apr 13, 2012
- Granite Bay CA
Sometimes, I've found that Engine Masters has already dyno tested a part that I was wondering about. They've done hydraulic roller cams VS flat tappets, headers with a variety of different mufflers, all sorts of cool stuff.
I don't recall seeing them do a back to back test of the popular Trick Flow heads versus Edelbrock heads.
Lets say a 500 cube engine makes about 550 flywheel HP with Edelbrock heads. Any idea of how much more the Trick Flows would make?
The Edelbrocks have the same intake valve size but the Trick Flow has a slightly smaller exhaust valve. The Trick Flow has 240 cc intake ports, the Edelbrocks have 210. The TFs have a 78 cc chamber, the Edelbrocks are 84. (At least the most popular ones are)
Now, I'm not coming out to say I'm going to buy the Trick Flow heads....But if I can sell a few things around here to justify the costs, I may do it.
I just want to know if they are worth the expense. A pair of the TFs will be around $3000 !
DODGE Trick Flow Specialties TFS-6161T783-C00 Trick Flow® PowerPort® 240 Cylinder Heads for Big Block Mopar | Summit Racing
