PRHeads
- 7:22 PM
- Aug 31, 2018
- So. Burlington Vt
Which high dollar Hyd roller lifters that fit a BBM, that aren’t the link bar style, do you suggest?
			Wasn’t meaning the link bar itself.Which high dollar Hyd roller lifters that fit a BBM, that aren’t the link bar style, do you
Sorry you’re having to deal with it.
My comment was more to set you on the hunt for BBM HR options…….. which I believe will show all choices are the link bar style.
Got a link for the other video?
In what world do you ever think the engine builder would ever take responsibility for that? Lol. Either way I’ll take full responsibility for what happened to my engine. I hired the guy, I bought the parts. I’ll try to do better next time.As discussed in multiple other cam threads, everyone blames the parts but never look for the root cause. Valve spring pressure and rate, coil bind, pushrod length, size, material and wall thickness, bore clearance and oiling among other things all factor into the equation. I’ve yet to experience a lifter failure that was purely a part failure.
It’s unfortunate when things like this happen for sure. Lots of finger pointing and uncertainty. All we can do is learn and move on.In what world do you ever think the engine builder would ever take responsibility for that? Lol. Either way I’ll take full responsibility for what happened to my engine. I hired the guy, I bought the parts. I’ll try to do better next time.
Throw those link bar type lifters in the trash and get some high dollar ones before it’s too late.
I did not use any special break in oil with my rb block roller cam set up .I’m not against using the high zinc stuff, I just wonder why it is still recommended given the drastic reduction in friction you see with a roller lifter setup.
Did you use a nylon or a 2 piece roller set up? My Mancini water pump basically sets against my timing cover. My builder says he still likes using the Nylon vs the 2 piece roller. I don’t know how he had the end play set but it all looked great.I did not use any special break in oil with my rb block roller cam set up .
I welded a s. steel washer to the inside of the timing cover where it would take the impact of the cam button ,
One could also a rig shim of sorts between the water pump and cover to further re in force the cover after getting the required clearance set , I have mine at .008 if I remember correctly , its been about 12-14 yrs ago when I built the engine ---------jfyi
They make cast iron roller cams? How do they hold up to the steel roller lifters? It would def solve the distributor drive gear issue.
Hmmm.....Pete covers this starting around 2.35:Let me guess....You must first measure the depth of the timing cover and gasket, then measure how far out the cam button sits out from the face of the block.....then somehow mill down the cam button to get to a number that is less than the depth of the timing cover by no more than .010.
I'm supposed to use a straightedge and plane across a tiny cam button to the face of the block? How is that done with accuracy?
