Question on Ram Charger intake systems
MikeyM
1:37 PM
NorCal
Hey all,
What's the difference between the RC air intake systems between a 383 and 440 B body car? Is it just the air cleaner height so it can seal up into the hood?
Thanks,
Mikey
Awesome. Thanks. Any idea how much difference in height?
Thanks, Hudson. So... if one wanted to swap a 383 to a 440 they would just need the correct air cleaner base, no?
Also, if one wanted to swap intake manifolds on either engine, they would need to make sure that manifold sits at the same level or lower (to make up with a spacer??), using the appropriate base. That sound about right?
Thanks,
Mikey
Yes, you would need the correct base for the engine chosen.
Any intake change will require measuring to ensure air cleaner fit
Thanks,
Mikey
Base is the big thing
Glad this post came up. I’ve got a 383 that been running a Torker for quite some time now. In the early days the set up was close to hitting the bottom of the AG box but abut 15 years ago I used the K/N air filter in the Moparperformance catolog at the time and was lower than the Fram CA305 and never had an issue with the K/N yet for clearance. Shorter air filter with the Torker gave me no interference and thought I’d pass the info on for guys running non stock single plane intakes. Worth comparing the 2 heights ( OEM FRAM and A/M K and N
MWbird, are you talking aftermarket round air cleaners or the different filter elements inside of the OEM RC housings?
Thanks,
Mikey
Thanks,
Mikey
Filter element Mikey. With the Torker 383 and Holley carb I used the KN air filter ( shorter in height than Fram CA 305 ) and no issues with the lid hitting the box but just make sure your air cleaner stud isn’t to tall or you’ll have a hole in the box. Rick
Thanks Rick. So please bare with me here... the CA3-5 is round so did you just use that round air cleaner in the RC air cleaner assembly? Apologies if I'm missing something.
Thanks,
Mikey
Thanks,
Mikey
Hi Mikey Yes the round filter KN
I did mine like this. Sealed up fine. That’s a 68 Coronet with a 400 and an edlebrock rpm performer. 3 inch filter.
Ah hah!! The picture is worth 1000 words, right? Thanks guys. That’s perfect. That is exactly what I was looking to do. Something like that.
Also, it’s great to know that a performer RPM intake will work with the ram charger intake, even if a different filter/top has to be used. I am good with that as long as I get colder.
By the way… The wife unit and I are flying out to Arizona to visit her brother but also take a look at a car that is super nice. Will keep you guys posted.
Thanks again,
Mikey.
