- 9:52 PM
- Apr 13, 2012
- Granite Bay CA
Sometimes, a small issue can have consequential effects.
With my first 440 swap in 2001, I had Cherry bomb mufflers bolted directly to headers for the break in. I had to hammer the mufflers a LOT to keep from rattling them against the torsion bar crossmember.
The car idled fine but above 2000 rpms, mine wanted to flop around and flutter like a Halibut on a hot plate. Once I put full exhaust on it, it smoothed out and ran strong. I figured that the restricted exhaust surely screwed with the carburetor transition between idle and primary circuit.
Another car, I had cheap mufflers and blamed them for weak performance of the car so I swapped in a pair of Flowmasters. Little change. I then replaced the pathetic SP2P intake with a mild Weiand and the car flat out scrammed once the choked off intake was tossed aside.
Seriously....that crappy SP2P intake was crap....the ports were smaller than a 318 2 barrel intake. I should have known though...I had one of those crappy intakes on a Chevy 350 years ago and that car was a slug too.
