Bob Jordan
Well CRAP. It's not an easy install and now there seems to be a problem with the switch.
Brake lights work 100%
Turn signal lever locks into place and signals work both sides no problem.
System cancels just fine both sides.
BUT
I was playing around to see if there was a lane change position (you know, where you move the lever but not far enough to lock in).
For the left there seems to be a lane change function.
THE PROBLEM - when I move the lever TOWARD the position where I would put it for a right hand turn BOTH REAR LIGHTS FLASH AND THE FLASHER CAN CLICKS. It's like a super secret 4 way FLASHER position but only rear lights flash. Pretty sure that's not supposed to be there.
Nine times out of then the lever and switch return to neutral but occasionally it finds that rear lights flash position. If I push the lever all the way for a right turn it works fine.
Oh well - good enough for now. I was trying to fix intermittent brake lights and that's fine now.
Anyone else ever seen this?
BUT
