j-c-c-62
So why then even have an "AMMETER" in the first place?
Are they mostly to indicate one has an operational alternator belt?
The original primary function of the ammeter is to monitor the health, charge/discharge status of the battery. Batteries from the time tended not to last more than 2-3 years with most failures showing an abnormally high charge rate prior to total failure. And abnormal discharging would indicate a charging system failure. Stock, as original, normal healthy battery and charging system, centered needle, shouldn’t be indicating any load current other than the battery. If you just want to know if the alternator is working, run a stand-alone voltmeter or an idiot light. Any serious monitoring of DC electrical system involves ammeters of some kind; there is a reason why they were designed into this system originally.So why then even have an "AMMETER" in the first place?
I submit "serious" would also include the omitted voltmeter, which unlike an ammeter has no real potential downside. I doubt the original single choice of an ammeter considered the intended reliable safe use for over 5+ decades................ Any serious monitoring of DC electrical system involves ammeters of some kind; there is a reason why they were designed into this system originally.
All meaning what? You left your lights on and the alternator is working to recharge it? A voltmeter would essentially indicate the same info. In reality, the driver can affect it in no real way except keep driving or stop driving.The ammeter shows the load status at the battery and, if you analize correctly, you can know where is coming the load being used and of course the alt status (after really understand the ammeter), but the gauge is PRIMARILY a batt status load reader
If discharge… all or most of the load comes from battery… you battery is being discharged. Your alt is not quite enough to keep up the load demands on car.
If charge… alternator is charging back the battery on discharged batt stage and IS BEING ENOUGH to feed the car loads demand
Is zero… the alternator is taking care of all the loads demands and battery is in rest stage. This is the IDEAL stage
This is JUST if car wiring is correct
If you begin to source added accesories from battery, the loads readings begins to be distorted and loads are running through paths weren’t designed to hold that extra load as a constant load stage (for example, the fuse link).
You can get a constant charge reading if alt is good enough but not really charging the battery while really feeding the accs added to the battery side. This is simply wrong and is an unnecessary stress added into the system, special at ammeter and bulkhead.
Then everybody blames the ammeters, while the culprit is the owners/mechs unknownledge
There would be absolutely no reason to monitor the system voltage while running the stock stand-alone ammeter, correct load placement, if the ammeter needle is centered, the system is balanced, and the alternator is operating at its regulated voltage level. Any change to that voltage level would be indicated by discharge on the ammeter, voltmeter would be useless.I submit "serious" would also include the omitted voltmeter, which unlike an ammeter has no real potential downside. I doubt the original single choice of an ammeter considered the intended reliable safe use for over 5+ decades.
You missed the point, a voltage meter alone pretty much gives a driver all they need to know, no real need for an ammeter. We don't care much if the system is in balance. What are we supposed to while driving, turn off the lights, radio, a/c, etc? We do care if the voltage drops or is dropping.There would be absolutely no reason to monitor the system voltage while running the stock stand-alone ammeter, correct load placement, if the ammeter needle is centered, the system is balanced, and the alternator is operating at its regulated voltage level.
We agreeNothing about these cars were designed to last more than a few years, until the next trade-in.
Yet we still read about bulkhead wiring etc failuresI’ve seen many of these all-stock untouched electrical systems/ammeters in perfect condition many decades on.
Add in 5+ decades of abuse, people screwing with system who shouldn’t be, there will be problems with anything.
Not so sure about. But I am sure with no ammeter in dash, it can't be the source of the problem, that a simple volt meter cannot produce.A properly maintained stock electrical system, correctly loaded, has no downside.
Not sure about the much more part, but I do question if the info it is telling you is really pertinent, or more so that a volt meter providesThe ammeter will tell you much more than a voltmeter only can if you understand what it’s telling you.
I agree, just like most modern cars on the road for the past 4? decades.You want to redesign this system, add a bunch of loads, place them at the battery or wherever you want, you should run a voltmeter.
So your point is an ammeter is necessary because of people improperly screwing with their electrical systems?
Sure it does, Same thing you would do with an ammeter. except you don't need a fire extinguisher to put out the fire started by the bulkhead connector.That doesn't make any sense.... if you had a voltmeter and you see your volts dropping what are you going to do ?
BingoVS
You have the ammeter and it shows a discharge , both are telling you the same thing.
Like what, because the time response according to physics must be the same the rate of change might be different, but if you concerned about a belt being tossed, both will indicate, and you will still have to limp home at the worst. Hard to imagine what electrical failure other than a bulkhead connector shorting would occur that would not be fused limited and an alternator could not overpower, but a volt meter would show as an unexplained voltage drain at high currents.Actually the ammeter would probably show you something is wrong before the voltmeter would.
Curious, how many car fires “started by the bulkhead connector” have you experienced or have first-hand knowledge of?Sure it does, Same thing you would do with an ammeter. except you don't need a fire extinguisher to put out the fire started by the bulkhead connector.
...a bulkhead connector shorting....
Don’t you mean fibbing?It's groundhog day around here again.
The charge system on muscle era mopars have caused issues from the day they rolled off the line. Saying otherwise is just not true. Smoked bulkheads on totally OEM cars was common, especially in hot environments with AC cars. Saw cars that were under 2 years old with issues. A balanced system would provide for adequate alternator output under all conditions, mopars engineers missed the mark.
Want to run an ammeter, run it. Want to run a voltmeter run it.
And a fuse link DOES NOT keep extra load at a constant load stage, it serves as one time partly slow limiter.
