74 Charger Rallye 440 TX9
I :BangHead:would guess the guy at the shop couldnt handle bending them.
Exhaust finally going in.
Jeff how are you working in this heat? I went out today and pulled the sway bar off the k frame and said all done. :lol:
Got the exhaust done. Original head pipes, Dynomax Super Turbos, and Accurate tail pipes. Everything aligned perfectly. I had to accomplish something on my last day of vacation besides cutting the grass and going to the dump.
You should see my lawn!
cut my back yard yesterday......... doing the front in an hour or so
that should complete my list of things to do before heading to the shop...... there's a bunch of cool stuff in there
Hey Jeff, I noticed your undercoating. Can you share with me the product that you use? Thanks
The underside is Raptor. Most of the wheel wheels and rear frame rails are original undercoating that I cleaned and touched up with the Raptor.
Dam Jeff that looks great. :thumbsup: Just came in from sanding my k frame. Hows the AC working? :poke:
nice job of working with what's there....... sometimes that's the way to go
AC is the cats ***. Did push 75 in there today though. Dropped it down to econo cool since it is back to work tomorrow and I won’t be back in there till Saturday.
Got the upper control arms ready to install. Torched out the bushings, blasted and painted all the parts.
Got the lower ball joints and control arm bushings pressed into the lower control arms.
