1968 Plymouth GTX
Got my engine back from the machine shop late this afternoon.
He checked everything out to see if it needed balancing and said it did not.
I also finally got the specs on my camshaft. Turns out it's an old grind that's not in the Isky Cams system anymore:
.485 valve lift both intake and exhaust
.050 duration is .244 for both intake and exhaust
108 Lobe Center
2000-7000 RPM range
Your cam specs are pretty close to what I put in my fifth GTX. Car had a Hemi grind purple shaft when I bought it. I liked the replacement better, worked well on the street with an otherwise stock engine. I saw your car has manual brakes, so the 108 lobe center won't pose a vacuum issue.
Thanks. The guy doing the engine work also thought the Isky camshaft would be good for my car, and he mentioned the purple camshaft as well.
The block had been painted black, orange and blue so it needed to get cleaned up and ready for Epoxy Primer and paint. Noticed that it has a Mellings High Volume Oil Pump on it also.
Decided to lightly media blast the block to give it a more consistent surface texture for the Epoxy Primer. Taped off all machined and bearing surfaces.
Then rotated block will spraying with compressed air to remove all media. Wiped down the cylinders and bearing surfaces to remove any dust.
I've done this....... paint will never come off that engine!
Yeah if it's too smooth, no sticky! Just remember that the Epoxy primer has a time frame for recoating with color
otherwise you'll have to rough it up with scotch Brite.
Looks good but I usually wait until it's assembled before I paint them. Lotsa little gasket edges and whatnot that need covering.
That's normally what I would do but in this case, I cannot afford all the parts for assembly at the moment and didn't want the block to get any surface rust forming.
This engine sat outside on a pallet for a long time before I bought the car, which had been disassembled by a local shop.
Right now I am going piece by piece through the additional parts: oil pump, power steering pump, water pump etc. to see what I can salvage and what is beyond repair.
I get ya'. In that case, painting the block was a good call.
