I"ve owned my 1968 Plymouth Satellite since 2010. It's the first rear leaf spring car I've owned. No stranger to changing flat tires, but have not had to change one yet on the rear of the car. I have removed the rear wheels a few times in my driveway and usually use a floor jack under the rear end pumpkin, then insert jack stands under the rear frame rails, lower the car weight onto the jack stands, and remove the floor jack so the leaf springs can hang down and allow removal of the 275/60/15 rear tires/wheels. If I was roadside with an unexpected flat, I likely would not be carrying jack stands. Then there's the fact that these cars are unibody and maybe not as rigid if jacking up from one side.
Any tips or advice on rear tire changes from those who have done it? I know the easiest solution is probably to use a tire repair plug, but what if the side wall blows out and it requires swapping to the spare tire in the trunk? This might seem like an obvious question, but I thought I'd ask you all.
