What's that tester gapped at? About an inch?Interesting. Everything on mine is "cold".
I am not getting a bright white spark.
Maybe you need a magneto.
Didn't realize it was some off the web pictureThe picture above is from Lakeland Auto and Marine YouTube channel.
Magneto in the distributor?
Yes more of a big block DP thing. The shafts and advance cams are clocked in different positions so for example if you set the oil pump gear in the factory #1 position and drop in a wrong clocked dist it might point to say #4 instead of #1. No reall issue you can just re adjust the wires for it to run.Has anyone ever heard of "clocking" a distributor?
200 millivolts crankingDisconnect the pick up. Connect the p/up to your DVM, AC volts, low voltage scale. Crank the engine. You should see from millivolts to a few volts. Zero means p/up or adjustment is defective.
All sounds ok & working. System should produce spark provided the rest of the system is ok.
It is possible that the main switching transistor is / has failed. This transistor is external and is a power Darling design capable of switching coil's primary current. If the transistor has failed, either failed open or shorted the resu,t is an intermittent spark or no spark condition.....just my opinion.....Correct, but for some reason, no spark.
I can occasionally get a significant shockwhile testing.
Where is the main switching transistor located?It is possible that the main switching transistor is / has failed. This transistor is external and is a power Darling design capable of switching coil's primary current. If the transistor has failed, either failed open or shorted the resu,t is an intermittent spark or no spark condition.....just my opinion.....
BOB RENTON
It's in the ecu. In layman's terms , and full circle, the box is shot.Where is the main switching transistor located?
