Dreaded shift shaft seal in car tips
chargers777
10:16 AM
nashport ohio
I bought the tool that screws into the seal. Didn't work anyone have any tips or tricks? Transmission is in the car.
do a search on a member dadsbee ,he had pics of how he did it.
Drop the valve body and knock out the seal from the bottom.
Take pictures of the valve body:
-installed before removal
-detail of selector gear positions and other arms
-just after you remove it and lay it down
buff out any wear marks in both shaft where they ride each seal.
I have never dropped a valve body. To be honest a little intimidated by it.
Super easy to do... just makes a mess. It makes the shaft seal much easier to install, plus it gives you a chance to clean out any friction material from the bottom of the pan.
I was 100% intimidated too.
But it was ok as long as you are are deliberate and cautious. There is a ball with a spring that goes against the detent. That can pop out. It's all about putting it back like it came out. There's like 6-8 small screw/bolts and it drops out. Much simpler than I thought/imagined.
Drop the valve body . Get a long bolt, a nut and two washers. Position seal. place washer on top. Put bolt through washer and seal. Put other washer on the bottom against trans. Install nut. Tighten bolt and nut , drawing the seal into the case.
10- 1/4" cap screw. Get a LARGE pan to collect the fluid and plan on letting it drip for a long time or wear goggles and a swim cap:).
I put aluminum foil down over a large flat pan to get a fresh clean surface. After I took the drain pan away. Then and remaining trans fluid on the foil, I could roll up in the trash.
I was able to pry it out with a small screwdriver . Looks like I need to learn to drop a valve body next time.
Many of the "before" scratches on the shaft area that I polished with rubber impregnated with grit grinding wheel were from trying to pry it out.
Did you replace the second little seal under the E-clip also?
That little seal is easy to change. It just sits under that E -clip. Not pressed in, so easy to pick out. Something to do if you are allready in there
