- 11:50 PM
- May 14, 2011
- On the Ridge, TN
For ye of short attention spans, I recommend skipping to the EPILOGUE and CONCLUSION sections.Cliff notes?
Thanks, but I'm well aware something actually killed that battery through a slow drain over the last month...Glad it was just a dead battery
Aye. The reliable ol' Ram will now fetch Fred a new battery and we'll be taking him out soon.congrats Ed, it's usually something simple......now go for a ride!
So watch where you're going Ed.FWIW The battery taking that final jarring bump could be the cause of it failing, one of the plates could have been weak & that shot could have caused it to fail & internally short out the battery..
Sheesh.So watch where you're going Ed.
Poor Fred.
Does Fred still have the early style regulator? If so the dual connection style alternator can be used by simply grounding one terminal....This whole thing did remind me of a question I've always had about Fred, though:
Why does he have an alternator with two FLD hooked up in back? Wouldn't a '68 have a single FLD?
No sir, he has an electronic regulator and each of the two "bladed" connections are wired up.Does Fred still have the early style regulator? If so the dual connection style alternator can be used by simply grounding one terminal....
Good early style alternator cores are getting harder to come by so many rebuilders simply substitute the later unit with instructions to ground one field connection..
Bob Miller did that when he owned Baby Blue during the 70s. He also installed automatic brake adjusters and a reverse warning light he pulled from junkyard donors. He saved the original numbers matching alternator and the wiring, along with the original fuel pump when he went electric. I passed those parts on when I sold the car the first time, sad but not surprising, they were gone when I got the car back in 2013.No sir, he has an electronic regulator and each of the two "bladed" connections are wired up.
I suspect the previous owner might have transplanted all that from a newer car (he did the electronic ignition
conversion the same way).
Thank you, you as well sir!Great news Ed, enjoy the rest of the summer.
Is that an NOS bungee cord?Marine Quality battery cut-off switch. NEVER had a no start. Ever. Even when modern car problems from extended storage.
