Trunk lid Gap at Dutchman Panel, 1966 Coronet
LSS&B
12:03 PM
Aylett, VA
Trunk lid: bought the car Jan 2025, with trunk out of alignment. Previous owner had car for 8 years and never tried to fix alignment. PPO, no contact info.
Right side needs to move 3/8-7/16 to front of car
Left side needs to move 1/8 inch toward front
Up down adjustment is OK
I am at rear of adjustment slots on both sides trunk lid. No additional adjustment at hinges, factory shop manual 23-44
Is best way to grind/file to extend the hinge bolt adjustment slots in the trunk lid toward the rear of the car?
Or should I try to bend the hinges? Looks from hinges that someone tried to do that with hammer and punch, but was not succcessful.
I have a 66 convert that was exactly like that. Ended up having to slot the holes.. worked out perfectly.
View attachment 1899726View attachment 1899728View attachment 1899729View attachment 1899731View attachment 1899732View attachment 1899733View attachment 1899734View attachment 1899735
I don’t think that’s fixable. You should just give it to me.
Thanks for the answer!
I suppose you removed the trunk lid completely first?
Did you use a small grinding bit or wheel on a drill to extend the adjustment slots?
