Paul_G
- 11:10 AM
- Dec 24, 2013
- Surprise, Arizona
I nicked a cam bearing while cleaning the block. So I got a set of Clevite bearings, took out the #2 bearing, Looked it over and knocked it in. Just changed the #2 bearing. Now the cam wont go all the way in. It stops about 1/8" going in to the bearing. very stiff trying to rotate it. Wont turn by hand. I knocked it all the way through. On the bench I test fitted it on the cam and the same thing, it is very tight getting it on that journal. It has no oil clearence at all. Should I use some 3000 grit and open it up? Send it back? What do you do when this happens?
