how visible where the cracks before the dye pen test?Cracked blocks are heart breaking event,MO. Here's a killer because of previous owners careless storage. When I was loosening the head bolts 2 were loose. I was checking the engine before buying my Satellite.View attachment 1900781View attachment 1900782
ouch, literally blood . sweat and tears?The split between cylinders was a smashed thumb not just sore.
I’m following this because I have a 440x6 that has had a real valve ping issue in the past. It now has something underneath the right bank. However it has a small crack in block on left side between the rear freeze plugs that doesn’t leak coolant but shows as a stain there. Edelbrock heads are on bench to cure ping before this happened.One wierd cylinder coolant leak I have seen in the past is a crack around a valve guide that leaked worse after the motor warmed up. Took a while to find, drove us nuts trying to figure it out. If everything else checks out, I’d start looking for something insidious like that.
could it be burning oil.............a friend asked if it could beoil buring and not water. Would oil cause the white valve? I'll test the valve as suggeted above and then plan to reiinsall the head just enough to test the cooling pressure,
