Looking for power brake booster & master recommendations
What’s that linkage on the back of the booster? The reason I’m asking is that the prior owner put in a power disc brake conversion and the brake pedal is way too high. The brake light switch also is hanging up on the pedal sometimes. View attachment 1906300
This may help with your question
regarding pedal height.
The linkage at the rear of the the
booster is a bellcrank.The pedal
assembly sounds like it may not
be original to the car.
There are brackets available that
will allow for lowering of the pedal/
booster while still using the original
4 mounting bolts for the booster
mounting bracket. The piston rod
center hole will need to be elongated.
[/URL]
Thanks, I'm going to measure that up today. It also seems like the brake light switch was put on backwards. It sits on the bolt instead of the pedal arm, and its catching on the arm. I'm trying to figure out what the hell they did.
In your pic, you'll see a second set of mounting holes for the brake light switch back from the 2 you are using. I had to move mine forward when I converted from manual to power brakes.
I do see those hole, but I was thinking that the switch should be turned around and mount on the other side, hopefully resting on the pedal arm instead of the bolt. I felt around but could not feel any holes to mount it
