nutz4spd
I want to add a fuel filter that has a return line and I’m questioning myself as to where to put it. Since it has a return port, should it go before or after the pressure regulator? My current setup is pictured below.
That’s what I have now. The clear one in the picture. I wasn’t sure if a filter with a return line should be before or after the regulator. I’m trying to cut down on a heat soak problem.If using a stock mechanical pump, I typically will put a filter directly after it to protect systems down flow... like a regulator and carb. If electric pump, pre and post pump, with tighter filter (lower micron) on the post side, which is before the carb/regulator.
No. The sending unit only has an outlet. The previous owner put a provision in the filler neck for a return port. I just picked up a 33040 from O’Reilly’s. Similar to yours only the return port is parallel to the out put line.Do you have a sending unit at the tank with a return?
Reason I ask is I ordered the below filter but I have a stock sending unit.
Wix Filters 495-33054 WIX Filters Fuel Filters | Summit Racing
That clear filter is garbage, they easily fail and leak fuel all over, ask me how I know.I left the clear filter that’s before the regulator for visual purposes and extra filtering.
Not sure if you have a carb or efi.I’m assuming that the return line is causing it to not hold pressure anymore.
The glass, the seals, the filter, the screw deal that holds it together.What fails on them?
The concept is great, a visible replaceable filter, but that particular filter can and will fail anywhere.
The only good filter, imo, are the stock metal sealed filters.
If you're worried about not being able to see when it's clogged there are other issues.
Gotcha. I just like the fact I can see the fuel flow. It helps in diagnosing fuel delivery problems should they arise. I'll swap it out though, just to be on the safe side. Thank you for the heads up.The glass, the seals, the filter, the screw deal that holds it together.
