Oil pressure gauge goes to zero
Another mod we would often do back in the day was install an aftermarket gauge pod under the dash. Which I have in one of my cars now. The first would be a mechanical oil pressure gauge. Do not use a plastic hose, use a metal-copper hose.
and a rubber grommet where it comes through the hole in the firewall.
I also plumbed one into the extra hole at the rear of the engine. This tee's off to a gauge under the dash. With the air cleaner on, it is pretty well hidden.
I would advise just the opposite. Copper has no resilence. Vibration will cause it to crack, break and spew oil all over. While you can't bend to shape like the copper, the plastic will withstand more punishment than the copper. Either way, you still need a grommet to pass through a firewall. Your call.
Plastic oil lines are not allowed in the NHRA.
I'm gonna hazard a guess that neither are copper! I suspect for any mechanical gauge with fluid in it you'd need a braided line. HOWEVER, I can attest to the fact that unless you're at a BIG NHRA event, nobody is even gonna look under the hood !!
You hazard wrong. Copper and braided are completely acceptable. If you want to skirt the rules while no one is watching, fine. Just don't kill someone doing it. Please.
Nope. Have you ever actually installed a mech oil pressure gauge ? On your, or a customers, car ? I'd like to know where vibration will cause the copper line to crack and break. I wonder if you know what to do to avoid that condition.
I have never used copper line on a car.
But we used to use it for coolant lines on machine tools. I have personally seen it fracture due to vibration from chatter.
We're discussing an oil feed line for a gauge on a car, not machine tools.
I realize that, but if vibration can crack a copper line, why would you want it on your car. There will be vibrations.
My under dash gauge came with a nylon tube, so I installed it that way. It leaked, so I replaced that tube with a copper one. So far, it has not leaked. I believe a couple of small coils can be wound into it to absorb any potential vibrations
Where have you ever seen copper line installed on a factory car? I will agree they also don’t use plastic tubing, but why would quality gauges come with nylon if it wasn’t safe?
If you want an upgrade from plastic, use braided.
I like it. Did you fab the piece or just off the Home Depot shelf. There is zero drivetrain chatter at all. It purrs like a (badass) kitten. While I’m ‘almost’ totally confident there’s pressure there, I can’t know at what pressure which is a concern. So your belts and suspenders is a help. Btw, what guage is that?
All, I may ultimately go mechanical but at this point I prefer not to run underway gauges. Only factory looks aesthetics.
I picked up everything at the local TSC store. I once had a 383 that would pop the red light on as the engine idled down. Rev it up, and the oil light went off. The pressure relief valve in the pump had stuck open. The valve is easily removed from its bore for cleaning, by unscrewing the plug from the back of the pump.
