452 head transplant help
Phoenix440
11:56 AM
Melbourne
Have a pair of rebuilt 452 heads I bought recently.
The heads should be an improvement over the 906s that have been removed.
The heads have new guides, some bowl and port clean up and multi angle valve seats, so expecting them to run better than the standard ( worn out) 906s.
The motor has a reasonable cam but the specs are unknown. The car doesn't make power until around 3000 rpm.
The 906 heads that were removed have single springs with dampers and there was one broken spring.
I suspect the springs were inadequate for the cam. The car always ran rich and may have been partly due to valve float.
The new heads have slightly wider diameter single springs with dampers and was told they can handle.480" lift.
Does anyone have an idea of standard spring diameter and how these compare? Just trying to figure if the springs are up to the job before installing.
Springs on 452s when measured with caliper across diameter are almost 7/32" (5./mm) Springs on 906s are 13/64"(4.8mm).
A couple of other questions:
The heads are the same thickness where the caliper is in the pic.
Does anybody have a standard head they could measure at the same spot. Im trying to see if the heads are shaved and if rocker arms would need shims( none were installed on the original heads)? Measurement on my heads is1/1/64" roughly ( 25.8mm).
I have been watching Nicks videos on youtube and he says 120lbs closed and 230 -280 lbs open spring pressure is good for a 440 with a .450 or .460 lift cam.
Im thinking this is a good guide considering the cam specs are unknown. The 440 is a hp block and may even have the original cam but who knows,any thoughts on this?
Any ideas much appreciated.
From pics: 906 head with removed valve;, is this a shim on the guide with spring removed, ( cant remove so assume it isn't but trying to figure if shims were installed on old heads).
The area around the guide is a machined flat for the spring to sit upon.
Use your caliper to measure the tappet at full lift and on the base circle to get the lift. Then multiply by 1.5 (assuming stock rockers are used) to get lift at valve.
452 heads on stock engines are the same heads as 906's, but with hardened seats. What has been changed on them in the last 50 years will have to be figured in out. To me what you have described is basically just a straight swap with upgraded springs.
Without knowing camshaft lift, how do you know you have the correct valve springs? Sounds like the springs on the 906 head may have had coil bind to break it. Don't really know without more info on the cam. Shot in the dark,so to say.
Lots of help here if you can provide enough info.
Good luck.
1. What’s important is spring pressure closed & spring pressure open.
2. That’s not a shim, it’s part of the vave guide.
3. If the cam is really unknown, you’re better off with a stiffer spring. Too stiff wears out cams fast, but too weak can cost you an engine
4. Double check for spring “bind” when installed on the motor at maximum cam lift
5. Pushrod length (or if you need/don’t need rocker shins) is best determined with the engine assembled
The typical intake guide boss on a 452 doesn’t lend itself to a lot of seal options(as they come from Mopar).
I’d also check to see what kind of retainer-to-seal clearance you’re working with.
That's the standard measurement at one inch.
I used 452's on my 440. Installing the Summit 6401 cam (.488 lift) stock springs weren't going to cut it. They recommended the Comp 911 springs which after doing the math they are a bit strong. So I went with the Crane 99839 springs. Whatever spring I needed they were a bit wide for the spring seats. So I ended up cutting the seats and installed spring cups. Also cut the guide bosses for positive seals. Did all the math for installed height and coil bind. Maybe there is a factory width spring out there for a higher lift cam but I couldn't find one at the time.
Some pictures in my "Showcase".
Items by khryslerkid
The springs I took off of the 452 heads when I bought them appeared to be stock.
Thanks for the info, looks like I will need to do change the springs.Do you happen to know the closed pressures of the crane springs ?
As always some great information from the members on here, really appreciate the help guys.
From your earlier thread……..
I don’t know if this is an optical illusion or what, but it looks like there are “humps” on the tops of the intake runners on whichever head that is.
I don’t recall ever seeing that before.
What’s the casting number on that head?
The casting number is 4006452, the runners look the same as the 906s to me.
What size are the spark plugs. They have the car heads and motor home heads with the 452s.
Plugs with a ring or crush gasket. See the recess...
Motor home head. Taypered plug. Note the bump.
The measurements are a big help, thanks.
I now know the springs on the 452s are at least bigger than standard and better than what was on the old heads. They measure 1.512" across compared to the stock spring in your photo at 1.4". Not sure how much more lift these are designed for but will be an improvement.
I now know the springs on the 452s are at least bigger than standard and better than what was on the old heads. They measure 1.512" across compared to the stock spring in your photo at 1.4". Not sure how much more lift these are designed for but will be an improvement. You don't recall the diameter of the crane springs for comparison?
Post #12
Good pick up, I didn't see that, they do have a hump under the plugs and the initial thread is tapered. So they are motor home heads? Are they inferior in any way?
Only the plug size. I've seen a few on here that someone used the non taypered plugs. It's the reason for the bump so you don't use the wrong style plug. Nothing else different that I know about. Many are using them.
Another tid bit about 452 heads. They have a ridge above the exhaust ports that could interfere with some headers. I had to grind a bevel on the flange for it to fit flat.
Wow never knew that, thanks, looks like a bit more work to do.
