- 3:55 AM
- Apr 13, 2012
- Granite Bay CA
We don't always drive in just the daylight. Who wants brighter headlights?
A couple years back, I added the headlight relay kit offered by a fellow FABO/FBBO member. This kit is strongly recommended if you have standard sealed beam headlights but considering the drastic reduction in current needed to power LED lights, I don't see why the relays would be necessary.
I had sealed beams for years but changed over to Hella H1 and H4 headlights.
The H1 are a single filament for use in either high beam only or low beam only. The H4s are dual filament for high and low.
These have replaceable bulbs.
In general, I've been happy with them but I need to learn how to properly aim them.
It seems that the low beam on the left aims low.
Same with the high beam on the left.
The right side seems to be aimed right. These are the lowest wattage bulbs that came with the headlights, 55 watt low beam, 60 watt high.
I'd be interested in suggestions on how to properly aim headlights without using any fancy equipment.
Thank you.
Also...Is it possible that the recessed headlights in the car affect how wide the light pattern travels to the sides of the car? It seems that it could as compared to a Plymouth Satellite or a Dodge Coronet.
Thank you.
