Air shocks
Scott Engelhardt
12:34 PM
Iowa
Does anyone make an air shock that doesn't leak? I have them on my Satellite because we load it heavy for our long trips. I would love a set that I only had to check once a week.
What brand are you running. Better question, what brands are there left. I can only remember Gabriel Hi Jackers and Monroe. The Monroe's all seemed to leak down.
It's got to the point... some time ago... where it's "does ANYONE make anything that's good" anymore. Maybe so with these. But, from extensive experience going back a half-century, your first check should be in the hose connections.
A squirt bottle with soap solution but you knew that. I always liked the Gabriel's because the air bags were protected inside the shock barrel. The Monroe's were clamped to the outside.
Shocks leak? Or the line kit?
Monroe is what I have. I have soaped the connections and can not see a leak
I inflated to max psi rating and the leak is where the air spring is clamped to the body of the shock
Couldn’t find the leak till I inflated to max rating. They are only a year old
HiJackers work. LOL
