Smoke might mean broken piston rings.......with oil getting into the chamber. Oil will dilute the octane rating of the fuel....& cause det.
It only smoked when I started hearing the noise and gave it the beans, out of frustration. No smoke any other time.
I’ve reread the whole thread. Detonation has been a common issue since the very beginning is what I gathered.
Time for a compression test.
List what you get for each cylinder.
Make sure you have a fully charged battery when you start.
I thought i posted the numbers. Will look them up and edit this and the original post.
you need to go to 3800 rpms to check total timing with vacuum advance unhooked. 29* at 2000 rpms is a lot for a street car.
I have no vacuum advance. I'll check my data log for timing at that RPM. With all the issues, I may not have a log that goes that high.
Update:
Drove the car last night. With coolant temp at 180, IAT 90, ambient temp approx 85-90°.
Zero noise. But it does this, some times.
Only change is a new coolant temp sensor.
Could I be hearing valvetrain noise? Oil supply issue? Oil pressure reads fine but maybe it's not getting to the lifters? Asking because I now notice lifter tick when starting the car. Stops after 2-3 sec. Kicker is I think I heard one continue to tick when pulling into the garage.
Lifters recently installed due to one ticking.
Just ran the car enough for break-in. Haven't changed oil so assly lube and extra zinc still in oil pan.
However, I did find paperwork from the original owner. He had it into a shop for detonation issues.
Who knows what kind of gremlin I'm chasing.
I can't even find information to prove that the degreed the cam, etc.
