33 IMP
- 6:48 AM
- Dec 21, 2017
- taxifornia,soon 2b Arizona.
I say a direct drive giant seven blade fan with eat more horsepower than a clutch fan... and a BUNCH more power than an electric or two.I couldn’t find the Engine Masters electric fan test. And at the risk of starting some **** I’m going to question some things.
1. Not such thing as free energy. So if an electric fan requires X amps to produce X cfm. That can be equated hp=VA/745.6. So if an alternator needs to make a that amount of amperage if is going to use a the same amount of hp.
2. The only way an electric fan can use less hp than a mechanical fan is to move less cfm, or visa-versa.
3. You can level the spike of load on the alternator with the battery, but in the end energy used
has to be = energy created.
4. Thus the only way an electric fan can use less hp than a mechanical fan is to move less air or the fan blade design be more efficient. I have a hard time believing one fan design for a car can use 10-20 less hp than a different design.
What say you?
I think my plastic flex fan is somewhere in the middle.
Funny thing. I have two giant electric fans on one of my cars. Idles at 950 with both fans on. Care to guess what it idles at with the fans off? (I'll give you a hint....950)
