68 Charger quarter panels
Painted the inside of the trunk, and have been working on the crease line in the quarters for a couple days. Its a little tricky getting two gently curved surfaces to meet in a line that is also slightly curved.
Boy this subtle little crease line has been a challenge but making some progress. It will look like hell if its not perfect and I will always stare at it every time I get in the car. Switched to black primer and figured out that running a piece of chalk along one side, then sanding up to the line is working, but doing that puts in low spots and Im starting over with more glaze.
Sanded thru 600, shell is looking pretty skippy now so I need to back away from it for awhile and work on running gear parts before my molasses baths start freezing at night.
You make it look easy, It sure as hell is not
I post up some pics, but nobody is there to witness the actual labor....... adding my car to the current lineup was beginning to kick my ***..... I had to get past the hardest part, and I'm there.
I'm about 12 days (120 hours?) in over the past 2 months; resurrecting work I did decades ago
must........keep.......going........
And you dont get to bad mouth the work that “last guy” did!
