Did you switch to LEDs? What did you use if you don’t mind me asking
Interesting wheels. What are they and what size?
All four are Hella H4 conversion lights. 2 are hi/lo, with 4300k (natural white) 35w HID bulbs. 2 are hi beam, with 3000k amber LEDs.Did you switch to LEDs? What did you use if you don’t mind me asking
So nice!!
That's what I run, they work well. Did you put them on relay's? It makes a difference.All four are Hella H4 conversion lights. 2 are hi/lo, with 4300k (natural white) 35w HID bulbs. 2 are hi beam, with 3000k amber LEDs.
Vision Plus 5.75″ Conversion Headlamps - My HELLA Lights
The HIDs came with a relay harness. Direct to battery, using the old headlight wiring as the trigger lead. The LEDs don't really care, they're stupid-bright anywhere from 10-18v since they don't dim on low V - they're either on (crazy bright), or off. No gray area (which is why I hate when people put LEDs in their DRLs - DRLs are high beams run at 7 or 8 v so they're dim..but the LEDs are full-tilt annoying as ****).That's what I run, they work well. Did you put them on relay's? It makes a difference.
T.I.A.
Thanks, I will have to check em out!All four are Hella H4 conversion lights. 2 are hi/lo, with 4300k (natural white) 35w HID bulbs. 2 are hi beam, with 3000k amber LEDs.
