Those are what I put on my 67.
Besides the bolts I did weld each end.
They did help my car, it was a solid car , pan but after 50 plus years they all get fatigued.
This is what I have done in several of my B and E bodies. Simple, tucks up tight nicely so you cannot see it from a side view, and makes a big difference in solid feel of the car and fitment of doors/glass.I'd just go with 2x2x3/16" square tubing - cut an opening in the rear frame rail to slide them in and weld and butt weld to the front crossmember. I don't think there's any advantage to welding anything the full length of the floor.
eck, that sucks.. on my 62 i didn't have to do any of that.. all different of course..If you go with the US Cartool, be aware that you will need to deal with routing the e-brake cable through the drivers side connector. I also modified the right side so a one piece fuel line could be used. I used the USCT's once and said never again. Rectangle yubing and a couple flat plates work just as well and are far easier to install.
Another vote for the home-made square/rectangle tubing approach.
The nice thing about the USCT kit though, they look factory when all done....good route if you're still in the build stage/everything's apart, interior out etc.
They will both serve the purpose.
Birdsong has another variation he does, where he continues the tubing through the crossmember and welds into the front frame rails.
I haven't tried his method yet, a little more work but a little more benefit as well. He has a video on the youtube somewhere detailing the install.
Thats the best looking sfc I have ever seen. They even attach to the torsion support in the same spot as the front frame rails. NiceNot mine but I sure like the looks of the USCT ones. They look like they were an integral part of the floor pan.
Is there any advantage to rectangular tubing vs. square? Stronger?If you go with the US Cartool, be aware that you will need to deal with routing the e-brake cable through the drivers side connector. I also modified the right side so a one piece fuel line could be used. I used the USCT's once and said never again. Rectangle tubing and a couple flat plates work just as well and are far easier to install.
Ditto, I like real world data.I would love to see actual data
I used 2"x3". That fits nice and you don't have to cut into the floor of the car.Is there any advantage to rectangular tubing vs. square? Stronger?
I cut virtually everything out of my 62 Dart, firewall, torsion bar crossmember, floors, relying on a few welded in supports.
Took before and after measurements and nothing changed.
The rockers are tied to everything and are substantial.
Not saying frame connectors wouldn't help, but it's not like the front of the car isn't tied to the rear, even the floor itself is structural, no?
USC has other pieces that interest me, the front torque boxes and inner fender braces, but too much $ for me at this time.
Yeah....I know. Like I said I haven't tried his method. I guess you'd have to hit him up on why he thinks it's better, but like many things on these old cars, the longer guys think about it and the more time they have for the internet, the more 'theories' they can concoct! I've come across some pretty silly "solutions" to things that in real-world terms would never have been problems to begin with.I blame JCC for questioning every modification that people do to their cars but sometimes the guy has a point.
I would love to see actual data showing the reduction in flex from adding frame connectors of all types… Bolt in, weld in, weld in including to the floor pan and then the Birdsong style that cuts through the torsion bar crossmember to tie directly to the front frame rails.
I put connectors in 4 cars so far. Only one was driven before and after. I noticed fewer rattles and an overall more solid feel but I wonder if I really felt an improvement or if I had myself convinced that it had to be better.(placebo effect)
I do think that they help but I would feel more confident with real data.
XV Motorsports did this very thing 15+ years ago. They were the first ones that I recall that made those floorpan fitting 3 sided weld in frame connectors. I know from construction that framing is greatly reinforced with plywood nailed to it so the theory of welding the connectors to the floor pan seems legit except…what stresses would the car endure that would benefit from that? Is the mid section of the car subject to parallelogramming? I doubt it.
My bonehead logic tells me that the frame connectors prevent the car from twisting like a corkscrew as viewed from the front or back. It seems that welding to the floor may not be of much value in that case.
I’m willing to debate though, in the interest of learning.
The Birdsong version though… is it really any better than welding to the torsion bar crossmember? Doing it that way means moving fuel lines on the right and brake lines on the left. Is there enough benefit from his design to make it worth the extra work?
Hopefully he wears a hat so people don't notice itI blame JCC for questioning every modification that people do to their cars but sometimes the guy has a point.
