l
the reason I highly suggest tubular control arms, and really that and good shocks is what I would call the bare minimum for a great driver, is because the factory alignment specs are completely garbage.
You don’t really understand or feel until you can change those specs. I’m not an expert by any means, but based on my experience the biggest positive change is your caster. The caster if im not mistaken not only helps keep the car stable at speeds , but it also helps keep your camber where it needs to be through all motions, which helps steering. And the more camber you run, the more it improves.
IMO for what they are, they don’t handle bad from the factory. But you make this change, it will completely change your opinion on how these cars drive, and if you don’t take your car out much, it’ll make it more enjoyable and you’ll probably drive it more
