not sure how much it will help but;
QA1 & SPC minus the brakes & spindles
on my 68 RR
weight of all parts suspension stuff combined with an single *
*all parts below
shipped weight are 38#s combined, including hardware
click on photos says part #s, a few misc. parts
explanations, ramblings
my Last Silver/Black 68 RR alum headed 479cid lowdeck,
I was doing 2 cars, mine & another friends car
to offset the expense of buying & building mine
suspension in/on both & I got stuck with the bill for & all the parts below,
(his wife pulled the plug)
among a couple other parts like 7 qt 7" deep Milodon oil pan & pick up
remote 2 Oil filter system, & Front & rear sway bars
(Sway bars & remote filters now on my current 68 RR)
a few others too more then just QA1 suspension parts
haven't decided what to use them on yet...
I have no idea what all
the take off OE stamped steel/flexy flyer parts
& org. K-member weights were
but;
all OE stuff were heavier for sure,
maybe 30#s or so heavier, combined
more then the sum of the tubular parts alone, it's not 1/2 the weight, like some say it is
but;
when I weighed/scaled the car
the nose of the car was nearly 70#s lighter,
Win Win for handling
& racing (weight transfer), tire wear, suspension/shock wear
or un-sprung or sprung weight alike etc.
but;
I did a couple other things & added weight back,
7" dep 7 qt Mildon Oli pan & HP/thicker HV oil pump, remote 2 Oil filter system
thicker 3 core MRE custom radiator, but still alum,
w/2 electric fans & electric motor water pump, considerably heavier,
big sway bar, 1-3/8" solid 'heavy' Summit brand, front & 1" adj. rear
(water pump stuff)
some maybe a wash with the factory steel non-clutch heavy 5 blade fan ? deleted,
for the org. brass core 22" rad, replaced with 22" MRE custom 3 core alum.
when I forced to use the org. but now Ported/smoothed off HP 68-70 Cast Iron,
OE style
heavy exhaust manifolds, w/3" head pipes
added like 20#s
2 times the weight of the Heddman mid-length headers I had
anyway;
because the headers wouldn't fit, because of the Unisteer "bolt in Rack & Pinion"
was in the way of the collectors, $1,000, I'll figure something else out
was gathering parts for a custom set of up swept & back style S/S headers
*Tubular K-member QA1, to be able to use the torsion bars still, not coil over
*QA1 Tubular & adj. dynamic strut rods
*2 Tubular LCAs QA1,
w/front sway bar attachment welded on already & pivots/bushings installed
*Tubular UCA are heavy, are not QA1's (QA1s are lighter) fixed lengths/or adj. too see bottom
they are
2 SPC dbl adj. on the car, R & L
easily get what ever angles & degrees you want
w/replaceable greaseable upper ball joints
***the Adjust. old QA1' were lighter,
not included in the 38#s
I'm sure they are lighter then the SPC's
*Unisteer 5-1/2" long tie-rod ends for more adj. with my
Bolt in Unisteer rack & pinion
I wouldn't recommend the rack & pinion, really limits Header/s choice/s
they are heavy but good addition, deeper threads
*& stock new Moog lower ball joins/steering arms for a B-Body 68 RR
not shown
