not sure how much it will help but;
QA1 & SPC minus the brakes & spindles
on my 68 RR
weight of all parts suspension stuff combined with an single *
*all parts below
shipped weight are 38#s combined, including hardware
click on photos says part #s, a few misc. parts
explanations, ramblings
my Last Silver/Black 68 RR alum headed 479cid lowdeck,
I was doing 2 cars, mine & another friends car
to offset the expense of buying & building mine
suspension in/on both & I got stuck with the bill for & all the parts below,
(his wife pulled the plug)
among a couple other parts like 7 qt 7" deep Milodon oil pan & pick up
remote 2 Oil filter system, & Front & rear sway bars
(Sway bars & remote filters now on my current 68 RR)
a few others too more then just QA1 suspension parts
haven't decided what to use them on yet...
I have no idea what all
the take off OE stamped steel/flexy flyer parts
& org. K-member weights were
but;
all OE stuff were heavier for sure,
maybe 30#s or so heavier, combined
more then the sum of the tubular parts alone, it's not 1/2 the weight, like some say it is
but;
when I weighed/scaled the car
the nose of the car was nearly 70#s lighter,
Win Win for handling
& racing (weight transfer), tire wear, suspension/shock wear
or un-sprung or sprung weight alike etc.
but;
I did a couple other things & added weight back,
7" dep 7 qt Mildon Oli pan & HP/thicker HV oil pump, remote 2 Oil filter system
thicker 3 core MRE custom radiator, but still alum,
w/2 electric fans & electric motor water pump, considerably heavier,
big sway bar, 1-3/8" solid 'heavy' Summit brand, front & 1" adj. rear
(water pump stuff)
some maybe a wash with the factory steel non-clutch heavy 5 blade fan ? deleted,
for the org. brass core 22" rad, replaced with 22" MRE custom 3 core alum.
when I forced to use the org. but now Ported/smoothed off HP 68-70 Cast Iron,
OE style
heavy exhaust manifolds, w/3" head pipes
added like 20#s
2 times the weight of the Heddman mid-length headers I had
anyway;
because the headers wouldn't fit, because of the Unisteer "bolt in Rack & Pinion"
was in the way of the collectors, $1,000, I'll figure something else out
was gathering parts for a custom set of up swept & back style S/S headers
*Tubular K-member QA1, to be able to use the torsion bars still, not coil over
*QA1 Tubular & adj. dynamic strut rods
*2 Tubular LCAs QA1,
w/front sway bar attachment welded on already & pivots/bushings installed
*Tubular UCA are heavy, are not QA1's (QA1s are lighter) fixed lengths/or adj. too see bottom
they are
2 SPC dbl adj. on the car, R & L
easily get what ever angles & degrees you want
w/replaceable greaseable upper ball joints
***the Adjust. old QA1' were lighter,
not included in the 38#s
I'm sure they are lighter then the SPC's, 2# to maybe 2-1/2"#s lighter
but, nowhere near as adjustable
*Unisteer 5-1/2" x 9/16"/14 fine thread, long tie-rod ends
for more adj. with my
Bolt in Unisteer rack & pinion
they are heavy but good addition, deeper threads contacts & more adjustability,
better thread contact, it only had like 1/2"_5/8" inside threads & a lock nock
prior, it has well over 'an inch+ of thread' in the tie-rod ends now
I wouldn't recommend the 'bolt in' Unisteer rack & pinion,
really limits Header/s choice/s
I have it on my current 68 RM23 68 RR
unless you want to still use the factory HP manifolds
(with Edel. RPM angle plug heads, with HP manifolds, you need to use shorty Accel style plugs)
or $1,100+ to $1,300+
TTI-383178 'Only off the shelf headers that will fit'
because of the hoses & the rack's in the way of the 2 front (#1 & #3) DS tubes otherwise
limits the oil pans you can use too, sort of defeats the purpose of the tubular K-member
I do love the way it handles & drive though, great feedback, just not user friendly
as to aftermarket parts
*& 2 rt & lf stock new Moog lower ball joins/steering arms, for a B-Body 68 RR
not shown
