Look at the photos of my old cherry picker... lifted and installed many engines over the 30 years I owned it including 700lbs of 6/71 supercharged early Hemi... never an issue. Short legs... no flimsy flat stock.Those "Unnecessary Show Straps" provide an additional 66.6% load support for the hoist. They are used to prevent the boom upright from tilting forward like yours did and breaking the bolts. The reason the back of the hoist was going "*** over Tits" was because the legs were not extended and the center of gravity for the load was too far forward.
1) The legs NEED to be extended when lifting heavy loads
2) The upright straps NEED to be installed
3) The proper hardware & bolt lengths NEED to be used
On a side note, I would suggest you download a manual for a "Cherry Picker" and read it before you kill yourself or someone else. Thankfully no one did with this mistake...
So how did you install engines without getting them over the core support?Look at the photos of my old cherry picker... lifted and installed many engines over the 30 years I owned it including 700lbs of 6/71 supercharged early Hemi... never an issue. Short legs... no flimsy flat stock.
Just couldn't lift anything over the radiator support.
Tired of running out of power is he?WOW..... 900 lbs.. after driving it 3000' down the road to the Son's.
I've had a few 50's cars with the core support cut and re-welded, seems like it was common back then.So how did you install engines without getting them over the core support?
This makes no sense?
Okay... seriously.no flimsy flat stock.
