There are 2 sliding pin latches with a tapered end that are spring loaded.
I think it's a Charger Jerry, so a little different than a regular sedan.Remove the rear seat. You can get to the lock with a long flat blade screwdriver and insert it into the lock from the backside, then twist and open. Hopefully you have long enough arms and screwdriver.
It's not the typical rear seat in these. They fold down but probably not like you're thinking. And the back panel folds down from the trunk side. It's definitely a puzzle.yeah on the 67 it should be easy to access from inside since the rear seats fold down.
Was the cross bracing cut out or were they really skinny??In high school I had a 67 Belvedere. The rear seat back was modified to hang on the upper hooks only. We would sneak people in to the drive in movie in the trunk. Plenty easy to crawl thru once the seat back is out.
Thank you. I'll figure something out.I just went out and looked at mine.
I'm not as optimistic as I was.
At least on mine from the inside the latch is up behind the rear window sheet metal.
I laid out some painters tape and took pictures of where they are located.
Let me know if you need anything else. I'm hoping to get it in storage on Saturday.
I'm still skinny, kindaWas the cross bracing cut out or were they really skinny??
My other Idea would be to drill through the sheet metal from inside right over the latch and make an access hole to push the latch down. With the plastic trim on you'd never know the hole was there.I had the similar situation with my 66 charger I tried to get to those catches from the inside of that fold down pane and had no luck. I ended up drilling out the lock. I hope you can get it….good luck
