Minii starter disaster job.
I'm going to try this one next.
I bought the AC Delco 1995 and eBay adapter a couple weeks ago based on another thread of the same subject. I haven’t been able to install yet due to some family issues the past couple weekends.
I’m planning to install it this weekend into the 68 Coronet with 383/727 seen in my icon. The car has been sitting for a few years and I’m trying to get it started so hopefully a new battery and starter is all it needs. It ran fine when stored and manually turns by the crank pulley bolt.
Edit: here’s the thread and the member who recommended the parts was Some Car Guy.
440 Starter Replacement
When I googled the Amazon parts number it also popped up on Summit.
ACDelco 88877195 ACDelco Starters | Summit Racing
This is the area I had a problem with.
Don't remember exactly where, but a fair amount of material needed to be ground off.
In the above pics a few posts up, one unit has the drive "shaft" extending into the nose bushing, and the other does not.
Which is normal?
I had a little trouble getting the snout in the trans hole. Check the diameter of the nose that goes into trans.
The two starters I tried did seem to have a gap on one side. Looked like a machining issue.
I ordered this starter, and it should be here for me to install tomorrow. I just hope the throw on the gear will be enough with this starter. I have to say though, it was allot cheaper than the other two I tried.
Now that I think about it, there was also an interference issue in the blue circled area-
You read about so many people dropping these into all types of big block classic Mopars without any issues. I wonder why a few people have issues.
Since Summit lists the same 1995 starter as Amazon, maybe they could shed some light on where any issues have been.
Everyone is saying "Just install a high-torque mini starter from a Dakota" but then there's cable extensions required and possible fitment issues due to machining...it's not a simple swap, evidently, and the vast number of different starter part numbers sure doesn't standardize things much...
Can't believe we're on page 4 for a starter... it's not a 36000 volt line that's gonna arc..
Yeah, it really is disappointing.
I'd expect to soon see threads discussing the difficulty of adjusting a fan belt, checking for vacuum leaks, the frustration with installing spark plug wires and a thrilling exchange on what torque setting to use on air cleaner wing nuts.
Sure, we all start off knowing nothing but ANYONE that has spun a wrench should be able to encounter a few obstacles and figure a way around them.
If nothing else, one should accept advice from those that HAVE actually had their hands on these cars before.
Here is a fact that may be a HUGE shock to some people:
Since the majority of replacement parts nowadays are NOT manufactured by original suppliers to our cars when they were new, the fitment and quality may be and often is lower. Some stuff needs some work to fit and function properly.
obviously not a starter, but the general idea is there
View attachment 1946913View attachment 1946914
I tried to use the shield as a template to test fit. The shield fits fine, but the starter still leaves a nice gap. The weird part is, nothing is protruding past the template on the starter. ‍ I give up, I’m going to get the OE one rebuilt, no choice
I measured them, they are both like 7/8'-1' wide. I'm not going to bother with this anymore. I found a rebuilder that has good reviews.
I measured the nose part that you have circled in red. It measured the same size as the OE starter and the hole where it goes is round. Something is stopping me from installing it all the way and I can't see it. Problem is, I don't want to hack up one of these starters only to not have it fit, and I can't return it.
But isn't this forum supposed to be about what guys are having problems with and they get discussed to hopefully find a solution? You think it rocket science to put a starter in? Sure, I'm having a problem putting in a starter that really wasn't made for a 67 Charger, but that's why I asked. Any place I try and buy a starter for this car only has the mini ones and I was trying to figure out why it's not working for my Charger. It didn't work out so I have to get the one that came with the car rebuilt. I've been out of the hobby for 20 years, and 20 years ago I could get the same starter at Autozone no problems.
I hate mini starters, mainly because of the sound. Nothing like a factory 1.8kw starter. You know it’ll fit, and it has the correct Chrysler sound.
Where are you buying NEW original type starters, not remanufactured or used?
As many have noted the parts stores are no longer carrying them.
Who said I’m buying NEW starters? I usually pick up factory 1.5kw or 1.8kw starters from a junkyard (I have a stockpile), or worse comes to worse, a parts store reman, and I go through it before installation. I’ve NEVER had a problem with a factory style starter; from 12 to 1 small blocks, to big blocks. I wouldn’t use a mini starter even if it was a NOS Chrysler part.
