How can I test the oil pressure idiot light
If I'm not mistaken you can do that. Make sure the ignition is on. It should work if you don't have other wiring issues.
Isn’t the light on when the car is in run position with the engine NOT running?
Supposed to be. A couple different things need to happen to make that work. Checking the wire to ground separately may help isolate where the problem is if he’s having issues..
When I got my Coronet the light was dead, I took a test light that beeps, one end to the oil pressure switch and the other to battery positive. Light came on with the beep, a couple of cranks and the light turned off. Easy diagnostic and was a load off my mind. Since then I've added a proper warning light to go with my DIY gauge cluster.
