Sickening- Cracked Block - Repairable?
dspur
8:51 PM
Albertville, AL
Engine is out and as far as I know there were no previous leaks, but I did not drive it that much before beginning restoration. The engine was rebuilt before I got it and certainly seems to be in good condition otherwise.
Had not noticed this until I replaced freeze plugs, and after the plug was removed evidently it seemed to be obvious, or maybe got worse at that point. Engine had been painted previously so it was not noticeable. Noticed it right after I had installed the new freeze plug.
I really don’t want to get another block engine, etc as this is matching numbers and I have a good bit invested in it.
Competent advice from those of you with experience is very much appreciated.
I saw this video a few years ago.... possibly the same for a plug hole.
That is absolutely how to fix it. My metallurgists consider this repair the best cast iron repair hands down. Done properly, can be considered as good as new.
Also looks like you have another small crack at about the 7 o'clock position.
My buddy had a '35 Nash that had a foot ling freeze crack that was repaired 70+ years ago with a brass plate, a homemade gasket and about 30 machines screws tapped into the block... never leaked.
One of the first big trucks I drove with a NH220 Cummins engine had a rod break thru the block. My boss fixed it with fibeglass and Black Magic bondo... ran 3,000 miles per week fir years.
I still have a 440 I rebuilt in the early 80s. I found a similar crack in it. I veed out the crack with a grinder and filled it with JB Weld. I hasn't leaked in decades now.
Lock and stitch is what I would try. And it's something you could do right in your garage. There are a bunch of videos on it on line.
Is it the numbers matching engine? If not, I’d pick up another 383 or 400 block and use it.
yes it's even in your quote reply..
Yeah, I missed that. Myself, I’d still get a replacement block and move my parts over. Save the original block and pickle it.
Get the lock and stitch setup and give it a go. It’s already cracked and it isn’t going to heal on its own. If it works great! If not then go from there.
That’s what I’d do.
That an easy repair I wouldn't spend the $$$ on another build. Drill it, pin it and weld it. It doesn't even seem to even be leaking right now.
I would pull the intake and check between the lifter valley for checks. I’ve got a 426 street wedge block that had a crack like that and it’s cracked inside also.
Thanks. I’ve had it off and did not notice anything, but was not looking either.
Well... The company Lock and Stitch is just down the road from me, for years they have sold their repair kits & repaired equipment at their facility while also having a crew that travels worldwide repairing cracks on heavy equipment, ships & anything else where the owners were willing to pay the costs... But it looks like in 2025 the company was acquired by Wärtsilä & the new owners aren't selling the repair kits anymore... I had heard something about it earlier this year but now searches appear to confirm that.. Other companies are selling the original design pins, the drill guides don't appear to be available... Though honestly that wouldn't be hard to fabricate..
https://www.ebay.com/itm/254255897225
