beebest
Any idea what this hole would have been for?
70 Road Runner non ac car.
Possibly, awfully low on firewall to be added unless engine was out. Also doesn't look drilled on the inside unless someone deburred it perfectly.Custom addition to the car.
Yes close to accelerator cable hole. Similar to AMD firewall, not as large and a bit lower.If You took a broader view of the area it would be easier to inform you. Being that it appears to be near the accelerator cable hole I think r413 is correct
Firewall (without A/C) - 66-70 Dodge Plymouth B-Body
Our firewalls are OE style and include all the holes, fasteners, bends and slots of the original. We even matched the OE wrinkles. This is an important part since many other components are attached or related so you can count on our panels to fit correctly right out of the box.www.autometaldirect.com
Never knew there was such a thing. I would have welded it shut when I prepped engine bay, but looked factory to me. I'll probably just put a cap plug in it now, if they make them for 1/2 holes.Looks like accelerator pedal linkage support. Maybe the car was supposed to go overseas?
