Dibbons
- 10:21 PM
- Nov 29, 2014
- La Paz, B.C.S., Mexico
I personally rebuilt the 1972 factory Thermoquad (6139S) after purchasing it used. Now installed on a fresh rebuild which we have just barely broken in the camshaft for twenty minutes. Idle sounds crappy and mixture screws turned in all the way have no effect (nor does unscrewing them). Putting the gearshift in drive provokes the engine to stall if idle is set to a reasonable speed. I'll be looking into a vacuum leak. May have to do a compression check to boot.
