- 10:53 AM
- Aug 18, 2024
- Virginia Chesapeake Bay
If so, there will be a nice used market available in about 5 years.Seen those thing all over the world. About damn time they're available here. Hope it's true.
Don't forget to add the 25% tariff.
| Specification | 2026 Toyota Hilux (U.S. Spec) |
| Engine | 2.8L Turbo-Diesel I-4 |
| Horsepower | 201 hp @ 3,400 rpm |
| Torque | 369 lb-ft @ 1,600-2,800 rpm |
| Transmission | 6-speed manual or 6-speed auto |
| Drivetrain | Part-time 4WD with low-range |
| Towing Capacity (max) | 7,700 lbs |
| Payload Capacity (max) | 3,090 lbs |
| Ground Clearance | 9.4 inches |
| Approach/Breakover/Departure | 29° / 23.5° / 26° |
| Starting Price | $32,000 |
The reason you'll never see that truck is the EPA.Need to have a cheaper 2wd version?
In fleet trim. None of that off road stuff. 2-door with longer bed.
2015 Hilux:
I seriously doubt it has all that stuff but I could be wrong. If you want all that you need to get a Tacoma.How much does it weigh?
Does it have a battery pack that uses the starter motor for EV boost power?
Does it have cameras to watch where my eyes are looking, microphones to listen to everything I say, alcohol sensors?
Can I get it without the stupid back up cameras and all that BS?
I like it has a 6 speed. So long as it does not weigh 5000lbs the ft. lbs should be adequate to move it out with a 6 speed.
This is closer than any of the American companies have gotten since 2009 to an actual "smaller truck". If I can omit or remove all the spy gear I will probably go check these out.
Specification 2026 Toyota Hilux (U.S. Spec) Engine 2.8L Turbo-Diesel I-4 Horsepower 201 hp @ 3,400 rpm Torque 369 lb-ft @ 1,600-2,800 rpm Transmission 6-speed manual or 6-speed auto Drivetrain Part-time 4WD with low-range Towing Capacity (max) 7,700 lbs Payload Capacity (max) 3,090 lbs Ground Clearance 9.4 inches Approach/Breakover/Departure 29° / 23.5° / 26° Starting Price $32,000
