Too Loose Small Block Dipstick Tube Options
Dibbons
8:14 AM
La Paz, B.C.S., Mexico
When I re-inserted the same dipstick tube in the 340 I rebuilt, sure enough it was a tad loose. Now that it's installed and running in the vehicle, it wants to just fall on out. The silicone or whatever I used to secure it was a complete and utter failure. Any leads for me on a decent replacement? Working on a '72 Satellite Sebring Plus.
If both surfaces are clean, maybe JB Weld will help take up the gap and also secure it place.
I have had the reverse problem in the past where the aftermarket tube is too big for the block hole.
This is where the tube fits in the timing cover? Might try one of the chrome plated tubes, they are usually oversized since the plating is over a standard diameter tube....
Oops.. Yeah, block... It's a Ford small block that the stick goes through the timing cover... Same general area...
I’d roughen the end of the tube, sandblast, 80 grit, something like that, especially if it’s chromed, then use the slow setting JB weld. Make sure both the hole and the tube are completely dry. A little in the hole, a little on the tube, fasten it, let it set up. Personally I rarely ever use silicone on anything that comes in contact with oil or fuel or coolant, too many times it just doesn’t seal.
I use Ultra Grey on all my dipstick tubes. They all have the holes drilled purposely oversize for slip fit and easy removal. None of them leak. Clean it well with brkeleen and a small round brush. Let it dry a few days before running it. This sealer dries slow.
Maybe try to put the biggest drill bit in it that will fit to stop it from collapsing and stake it with a center punch a bunch, put some ultra on it and send it.
Especially the chromed one from Mopar Performance. Had to emery cloth all the chrome off to get it to fit!!
I usually put the tube softly in a vise and take a tapered punch or equivalent and spread the bottom out some. Then seal it with anaerobic sealer and drive it in and let dry. Old guy showed me that years ago on a 440
